285's? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 01-12-2013, 06:12 AM
285's?
I have stock 2012 f250. Came with 17" 245's (look aweful). Looking at BFG 285/70/17's. BFG says will fit on 7 1/2" rim. What do you think? Will I have any problems with clearence (at full turn)? Thanks.....
Old 01-12-2013, 09:11 PM
I have 295's on my 2011 18" wheels that are 8" wide. Absolutely no rubbing. I know some guys put 35x12.5 on stock wheels with no rubbing. Are you sure your stock tires are only 245?
Look at my public profile if you want to see pics.
Old 01-28-2013, 03:33 PM
From what I've heard/read about tires in the past, you want to stay within 1" of tread width and rim width for optimal tread wear.
Old 01-28-2013, 04:38 PM
285s are for chevys
try again!
Try a 295 at least. and bfgs are boring. im unsure about that 245, but if thats what you got, then thats what you got. most of these trucks are at least a 32 inch tire from factory.... and yes there are several that are running a 35s on the new trucks. i think id stick around a 33 or 34 just to be safe...unless you are thinking about leveling or lifting later.....then id buy the bigger. 295/70/17 is a nice 33x11.5 ish wide. I wouldnt want to go much wider then that, i think they look funny when they balloon too much.
you could get by with a 305 width as well and probably get closer to a 34inch tire. Im unsure of what bfg offers in metric.
