Sponsored by Discount Tire |
Anyone ever run the 42" radial military tires?
I can get the 42" radial military tires for under a grand for all 4..but I hear they are horrible on the road and very heavy which causes balancing problems? Only seen these statements from 1/2 ton truck guys so looking for anyone that may have experience with these good or bad
military grade tires, im sure there heavy as hell, eventually it would prolly tear up parts, just cause of weight and size
I have read all over that they are around 200 lbs each and that they wear out really fast on the road.
My RAZR made me send this... |
You can buy the 40's or the 42's...
Everything I've had experience with on these tires.. If you find a new pair (only a year or 2 old) They will do better on the street.. because they are softer... Big bonus of these as opposed to other 40+ tires is they are not very loud. If you find an older set (3-5 years old) They will be very hard, Street manners wont be as good.. But they will wear like steel and last you a long time.. Though what they have already said, The Tires are HEAVY AS ****. and will wear down parts faster.. Expect to have to buy the most expensive Ball Joints/Breaks/Tie Rods, TRE's/ Driveshafts... Everything will need to be beefed up over time as stuff wears out, to ensure reliability.. But, If your stepping up to that sized tire, In a SuperDuty.. For the cost, those tires are the way to go. |
Guess I will be holding out for 40" Toyo Mt's..Not worth the extra hassle to get a set of cheap tires.
I only ran the military Michelin XL's in the 38" size and they had pretty good road manners and high towing capacity but I thinks thats because they are so skinny as compared to my 42" tsl's I have also ran.
I have a set of those military Humvee tires on one of my trucks right now and real impressed with the road manners but they are so tiny! |
I run Toy 37s on a 20" rim, tire alone weighs almost 100lbs each, I would guess 40s weigh close to 120... smaller wheel would have more rubber and more weight. Toyo's website should have the actual weights. |
