Sponsored by Discount Tire |
Locking DPF cap (to keep Diesel out)
My Step Father asked me about this the other day and I looked into it and could not find anything on the market. My Son bought my 2007 Chevy LBZ, he works in the Eagle Ford Shale in South TX. Since they are well paid many buy diesel trucks and do not know a thing about diesels and to them its just another tank to fill, like a reserve tank.
So in short I think it was a bad design to put the two filler tubes next to each other and also green (and Yellow to a lesser degree due to E85) are Diesels colors. So I think Making the DPF cap green next to the fuel tank filler tube was just a bad idea like plastic oil pans on the 2011's and then they changed them to metal for 2012. I am sure many of you have thought about the design, and when two of us got talking (Step Father and I) We said the solution was a locking cap but none to be found. Anyone....anyone.....? Last edited by hood72; 12-07-2012 at 08:30 PM. Reason: hey sorry i was wrong on the cap colours but either way bad design, but this sure got a lot of repys, thanks... |
I'm assuming your talking about UREA or DEF not DPF. I can understand how it's an issue, especially with the kind of thinking you describe, reserve tank. heh.
On the Ford's, it was done with a Green Diesel cap and a Blue DEF cap like the following, ![]() The Chevy's look like this, Pretty obvious but if you don't know diesels it could be a pretty big mistake. Here are some links I found for locking DEF caps, no idea if they will work though for our size openings. http://www.class8truckparts.com/Volv...B003U2V73Y.htm http://www.iveco.com/ivecoshop/en-us...Adbluecap.aspx http://www.truckprotect.com/adblue http://www.fueldefendusa.com/products/def-caps |
well if your son bought an 07 he wont have to worry about DEF and you cant fit a regular nozzle in the DEF tank so you shouldn't have anything to worry about.
WHY IS THIS THREAD IN THE TIRE AND WHEEL SECTION ??????????
The OP has 6 posts.... Thats my best guess.
Sent from my LTEVO using AutoGuide app. |
You said , if you don't know diesels.....
Well I do not know how to say it nicely many people in the oil fields never have drove or owned a diesel. On top of that many can make big $$ so they go out and buy a Diesel and do the, sorry if I offend any one to make up for a small .... they go out and buy one and put crazy lifts and tires and all sorts of gaudy things on them. its one thing to have a grille guard ,headache rack and toolbox, but when you can not get in your truck without a step stool or climb the tires or the like....
and thing they do not do if modify the brakes , suspension to handle the added rotating mass from the big foot size tires and rims. sorry if I went off topic and ranted Quote:
Well thats why I did not make it a blanket statement and said "many" , but you also have to know the machismo. It is a culture type of thing I understand it as I have grown up in south TX. Also like I said you Need too, when doing some alterations do other like the brakes fender flares to keep the tires from throwing rocks and more on the truck itself and others around/behind.
But ok put 40" tires and a lift big enough to clear the tires and little more for safety. But the other day I saw a truck at a speed shop had maybe 36"s? but had a 12" or so lift and it was silly because it was a ford not a HUMMVEE that has independent front and rear suspension, so the bigger the tires the more ground clearance. To me trucks like that are like nose rings/studs on women some look so sexyaome make you do a second look like hmm nice and then theres the ones that make you say WTF (much like spandex). Sorry if I Irked anyone but I am sure you know what I meant. |
