05 Brake Caliper Removal - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 11-11-2012, 06:50 AM Thread Starter
What's the trick to removing front caliper? Got the wheel off and the top slider pin is seized. Removed the top and bottom bolts, but I still can't get caliper off. What am I missing? Thanks in advance.
05TwoFiddy is offline
post #2 of 8 Old 11-11-2012, 06:56 AM
ZMANN's Avatar
Quoted: 1335 Post(s)
are u sure you pulled the right bolts ? I know there is a set that confuses some folks in the same area or that may Be the rear caliper ?
if the rotor is grooved you may need to pry the caliper open a bit
We Miss you Ronnie
ZMANN is offline
post #3 of 8 Old 11-11-2012, 07:04 AM
ZMANN's Avatar
Here is a pic
I am sure you pulled the right ones but just dbl checking
Name:	05 caliper.jpg
We Miss you Ronnie
ZMANN is offline
post #4 of 8 Old 11-11-2012, 07:31 AM Thread Starter
Thanks Z,
I pulled the right two bolts. The caliper seems to be hung up on something. I pulled the line bolt off too. Still won't come off. I'm sure it's something stupid that I'm missing.
post #5 of 8 Old 11-11-2012, 07:46 AM
04cr450's Avatar
dont be afraid to use a hammer and tap around it.. They dont want to come loose from the rotor. Hit on the outside part where the bolts go in at..
04cr450 is offline
post #6 of 8 Old 11-11-2012, 07:53 AM
ZMANN's Avatar
ya you will get it you just have to ramp up your anger a little lol
We Miss you Ronnie
ZMANN is offline
post #7 of 8 Old 11-11-2012, 09:41 AM Thread Starter
Released my inner Hulk. Came right off. Bam! Thanks for the help guys!
post #8 of 8 Old 05-29-2014, 11:15 PM
llangarica's Avatar
i don't mean to revive such an old thread here but you have to be careful when prying off the calipers without compressing them first. some of the pads have these stupid pins on it and when you pry them off they tear apart the pistons on the caliper... learned that $200 lesson the hard way...
2005 Ford F250 FX4, Sinister Diesel goodies, ARP Headstuds, SCT Tuner, Innovative Diesel Extreme X Tune, Powermax Turbo, S&B Intake, Autometer Gauges, RCD 4-link 6" Lift, 33" Tires on 17" American Racing ATX wheels- SOLD [/url]
llangarica is offline
