Will this fit? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 11-09-2012, 07:47 PM
Will this fit?
I have an 05 with an 8 inch lift. Will 20x12 Fuel Hostage wheels with 38/13.50/20 fit? The tires are probably at about 30%.
Old 11-09-2012, 07:56 PM
Yeah I have 38"s under a 6" lift
Sent from my iPhone using Autoguide.com Free App
Old 11-09-2012, 08:06 PM
thanks for the quick response! how wide and what offset you running?
Old 11-10-2012, 07:23 AM
They're 14.5 wide not sure on the offset
Old 11-10-2012, 10:06 AM
no they will rub a little on a 05+ truck. If you go to a 10" wide wheel you'll be fine. If you want to run the 12" wheel you will need 10" or more of lift with that size tire.
Old 11-10-2012, 11:23 AM
Hmmm so if they rub too bad could I put a leveling kit on?
Old 11-17-2012, 08:28 PM
It worked..just had to do some minor trimming.
