Wheel Adapters??? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 10-16-2012, 10:06 AM
Wheel Adapters???
Just picked up a set of 8x6.5 wheels with tires on them and was gonna sell the wheels but like the way they look sitting against my truck....am I making a mistake putting adapter on such a heavy truck and if not what kind should I go with?
Old 10-18-2012, 09:11 AM
For the amount of money that you would spend on good steel adapters, you could buy those wheels in an 8x170 pattern. Also, however thick any spacer is will push the tires out that far.
Sent from my LG-VS700 using AutoGuide.Com Free App
Old 10-18-2012, 04:43 PM
I would not chance it. It isn't just about adapting lug pattern but also about transferring the load. Your truck's stock wheels are hubcentric and chances are most wheel adapters won't be.
Food for thought
Old 10-20-2012, 05:29 AM
If you can get a set of quality adapters and reach lugs it will be fine. The Alcoa Billet adapters are stronger than you think. They will be EXPENSIVE though.
Old 10-20-2012, 05:36 AM
not worth the coin IMHO and IIRC the minimum for an adapter is 2 or 2.5 and you still need to grind of some of the stock studs
Old 10-20-2012, 05:50 AM
You maybe correct.. Im doing it but its semi Wheels going a Dually.$800 for adapters
Old 11-29-2012, 08:08 PM
I know this thread is old. If you run an adapter with two sets of studs, facing opposite of each other you can run a much thinner spacer. My adapters are .850 thick. Think outside the box.
