max tire size on stock truck - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 10-12-2012, 11:08 AM
hey guys, my current tires are getting low on tread and i have a feeling i will need to replace them before i can afford to lift it since i will not have a job starting at the end of the month (enrolled in police academy, im not lazy or a bad worker) i currently have 265/75R16E tires on 16X7 stock wheels.
i would like to go bigger and not have to worry about rubbing or anything like that. any recomendations?
-Brian
2002 f350 4X4 w/ 3.5 factory block in rear.
Old 10-12-2012, 02:36 PM
i would do some 285-75-16's
Old 10-12-2012, 06:40 PM
I've seen those on my buddies truck they look like a decent size. Wasn't sure if there were other options available. That converts to about 33" high correct?
Old 10-14-2012, 03:13 PM
I run 285-75/16 on my truck that is lifted with a leveling kit up front and a helper spring in the rear. Cost me less than $500 with 4 new shocks. Also just installed new Cooper ST Maxx 285's
Old 10-14-2012, 04:25 PM
but thats not the biggest 99-10 35 i think is the biggest without trimming but 37 will fit if you trim the inner fender Ive had 1999 f250, 2000 f350, 2002 f350, and now a 2010 f250 no lift on any of them but Ive always ran the military tires because they are cheap and hold weight well.
Old 10-14-2012, 05:10 PM
I think 35's rub the leaf springs at a full turn? So yes 285's would be tha largest with no rubbing issues. I could be wrong.
Old 10-22-2012, 10:28 AM
Will the 2008 F-250 20 inch rims fit a 2006 F-250 without changing anything or adding a spacer
Old 10-22-2012, 12:17 PM
what is the biggest rim i can fit on my tires if they are 285/75/16's.
its 16' rims right?
Tags
clearance, maximum, size, tire, wheels
