Confused and need help on suspension/wheel/tire combo - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 10-07-2012, 06:13 PM Thread Starter
Hennigan's Avatar
Edited:
I think I found what would work for me. Will this level work? Not looking to sit completely level just want a tiny bit more room to mount 285/75R16s on my factory 16x7 xlt chrome wheels. Also will I need anything else like a trac bar or new shocks or alignment to make this work?
http://www.alligatorperformance.com/...ty-p-7277.html
Current:
2012 Mustang GT 5.0 M6
SOLD:
2006 Dodge 2500 QCSB 5.9 Cummins
2004 F250 CCSB 6.0
Last edited by Hennigan; 10-07-2012 at 06:49 PM. Reason: figured out solution possibly
Hennigan is offline
post #2 of 6 Old 10-08-2012, 10:17 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
Work yes but both ends should be replaced to keep the Pinion and Castor the same.
Those tires should clear...
CT Performance, Inc. is offline
post #3 of 6 Old 10-09-2012, 04:05 PM
My truck had 285s on 8 inch Centerlines when I got it, no clearance issues.
That piece will start more problems than it will solve. Either get a real leveling kit, or leave it alone. Pro Comp makes a 2 inch leaf spring, Top Gun Customz has a front and rear leaf spring relocation kit, there are several options. I used an add-a-leaf up front, it didn't work well, ended up getting lift springs.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #4 of 6 Old 10-09-2012, 04:08 PM
Quoted: 4 Post(s)
X2...Depending on the amount of lift you want the best riding kits will be either hanger kits or a mini spring pack..limited to 2.5"
Hangers for a level kit 2-3"
Mini spring packs can reuse stock length shocks, hangers need longer.
Both kits require a adj track bar to recenter your axle.
We have all, PM if we can help.
Have you measured to see what height you need?
post #5 of 6 Old 10-09-2012, 04:17 PM
When I had just an add-a-leaf, I didn't have any problems with wander or tire wear normally associated with off center axle. The Being as the O.P.'s truck is a leaf sprung like mine, I really doubt he need for an adjustable track bar on only 2" of lift.
Karls03 is offline
post #6 of 6 Old 10-09-2012, 04:37 PM
Quoted: 4 Post(s)
Its geometry any lift will start shifting the axle..2" can shift 3/4" First what happens is the springs will shift on the bushings...not good then if needed twist the top and deform that bushing...Old saying..if its worth doing its worth doing right.
