Sponsored by Discount Tire |
Will these wheels work....?
I've been looking for a new set of seventeen's for my 05 F250. I found a set that are 17x9 with -12 offset and 4.5" backspace and 130.8 center bore and of corse the 8x170 bolt pattern. The compatibility chart says they won't work could someone tell me if this is right or wrong and if they will or will not fit.
Thanks |
Correct me if I'm wrong, but don't you have to run at least 18s on the 05-07s due to the brake rotor size?
The factory wheels are 17's.
Thanks |
Ok, I wasn't quite sure.
My factory ones are 18's...
Even if an 05 will clear 17s (think they will) that back space is for '99-'04. Starting on '05 the axle track got wider necessitating more back spacing.
Just found them on the tire rack web site and it says they will fit but requires a lift. Now my question is would they work with a 2.5" leveling kit running 35's.
Thanks |
I'm running 35's with a 2" leveling kit and it's fine!
I've seen 35s on factory 20s w no issues
Sent from my Motorola Electrify using AutoGuide.Com Free App |
Rolling 35s with a leveling kit relies on 2 things, backspace and width. proper backspace for that year on an 8 inch wide wheel or narrower will work. Anything wider, or wrong backspace (4.25 on an 05 and up) and it's rub city. |
