37 and a 4.5 " lift - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 08-31-2012, 09:54 AM
37 and a 4.5 " lift
Will 37s fit with a 4.5? See where plenty of ppl are sayin 35s clear easily
Old 08-31-2012, 10:42 AM
That all depends on the back spacing of your wheels.
Old 08-31-2012, 11:57 AM
Thinkin american force justices 24x14 which is -73 offset or the 24x12 which are -43 offset. Do you think itll work
Old 08-31-2012, 12:05 PM
37's and 4.5" of lift works great with 9-10" wide wheels with 5-5.5" of backspace. 14" wide wheels regardless of backspace will present some serious challenges. You would probably need about 8" of lift to clear those.
Here's my 08 on 37's with a Pure Performance 4.5" Triple Threat kit:
Old 08-31-2012, 12:09 PM
If the nackspacim is the same it shouldnt matter right? I mean 4.5 inches of backspace is the same on all wheels right
Old 08-31-2012, 12:41 PM
Running that wide of a wheel and that much backspacing, your going to scrub like hell!! Im lifted 6" 20x12 -44 wheels, 35" tires and If I turn all the way and hit a decent bump it will scrub the rear fenderwell SLIGHTLY. I want to run 37's, but I know I will have to do some major trimming.
With only lifting 4.5" Id go no more then a 10" wide wheel. Or run a 33" tire if you HAVE to run such wide wheels on such small lift..lol
Old 08-31-2012, 01:44 PM
I dont HAVE to i was jus wonderin. Think imma go with a icon 7" or a 8"(not sure which brand) i jus kinda like the look of a lower truck with bigger wheels and tires
Old 08-31-2012, 08:35 PM
37's fit a 6" lift perfect, should go with that
Old 09-01-2012, 02:06 AM
They fit perfect with a certain tire and wheel combo......Read the wheels he was thinking of using. He wouldnt hardly clear with a 6" lift with that offset and be functional
Old 09-01-2012, 04:22 AM
Preciate the help guys
