2001 F250, Wheels stuck to hubs - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 12 Old 07-14-2012, 09:31 AM Thread Starter
Any tricks, I've tried various sledges and pry bars to no avail. They are the 4X4 chrome rims that came with the truck 16"
Thanks.
Chuck Jaxel
cwj1063 is offline
post #2 of 12 Old 07-14-2012, 09:34 AM
Hville's Avatar
Last time that happened to me I used pb blaster, then a product from kimball Midwest that lubricates and chills the hub... One smack and they came right off.
2005 F250 FX4 Lariat CC SB 6.0
ARP Studs, OEM Gaskets, Fuel Pressure Spring Upgrade, STC Fitting Upgrade, RCD EGR & EGR Cooler Delete, Mystery Tune, Straight Pipe w/Cat Delete, 5000k Bi-Xenon HID's, 5% Tint all the way 'round.
Hville is offline
post #3 of 12 Old 07-14-2012, 10:01 AM Thread Starter
I tried PB, will to look for this other stuff when I go for the brake pads.
Thanks.
cwj1063 is offline
post #4 of 12 Old 07-14-2012, 10:06 AM
duct tape & zip ties
bigcountrysg's Avatar
Well, I would put the lug nuts back on but not fully tight. Then lower the truck back down so it is resting on the tires. Start the truck up then turn the tires left and right. Sometimes that will break them free from the hub. It works best to be on a hard surface like concrete or asphalt. Because on grass, dirt, or gravel you will just dig holes.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #5 of 12 Old 07-14-2012, 10:10 AM
ZMANN's Avatar
Quoted: 1456 Post(s)
I like that idea ! Smart
We Miss you Ronnie
ZMANN is online now
post #6 of 12 Old 07-14-2012, 10:32 AM Thread Starter
Good idea for the fronts
My current issue is with the back tire.
Thanks.
cwj1063 is offline
post #7 of 12 Old 07-14-2012, 10:39 AM
Hville's Avatar
This is basically the same as what I used.
Hville is offline
post #8 of 12 Old 07-14-2012, 10:42 AM
Hville's Avatar
Just spray it on the hub though so it will contract and the wheel won't.
Hville is offline
post #9 of 12 Old 07-14-2012, 11:03 AM
dieselflash's Avatar
Go with your inner Gallagher and break out the Sledge-O-Matic!!! Hit the tire from the backside.
Ford Master Diesel Tech
dieselflash is offline
post #10 of 12 Old 07-14-2012, 05:58 PM Thread Starter
Got em off
Good quick swift kick from behind the tire did the trick, other side came off surprisingly easy. Go figure. Thanks for all the replies. Brakes were toast, one pin was seized, basically good stopping now.
Thanks again.
Chuck
cwj1063 is offline
