Sponsored by Discount Tire |
Popping noise in right front wheel
I have a 2000 F-350 Super Duty, 4 WD, crew cab, long bed, 7.3 PS.
I have a popping noise in my right front wheel, but it stops when I apply the brakes. I have taken the wheel off to see if anything might be loose, but couldn't find anything that looked wrong. I did talk to one guy that said it was probably a bad hub. Does this sound like it could be the problem? If it is a hub that needs to be replaced, where would be the best place to buy one? Thanks for the help, Tinman |
Nope. I still have the popping noise. Guess I'll wait till the wheel falls off doing 70 mph, then I will know what was wrong.
Wish I could help. Tinman |
Mine did the same thing for awhile. Turns out it was the ball joint. Give this a try, take a good light and very closely look at the ball joint and look for a rust powder around it. The factory joints dont have grease fittings and seize up and the result is rust. I ordered an online kit that came with MOOG greaseable joints and factory ford replacement seals for both sides of the truck.
Thank you Sir. I will take a close look at it today.
Ball joint is also my guess. different vehicle but on an olds bravada i had it also made a popping sound when they were bad. are you getting any abnormal wear on your tires?
No additional wear that I can tell, but I'll start watching it close.
