King ranch rim questions help ASAP - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 07-02-2012, 07:29 AM Thread Starter
tylerb05's Avatar
I have a 2003 ford f 250 king ranch with the 16 inch rims 6.0 and I bought the 2004 king ranch 18 inch rims they made will these go on without a problem . I've read the offset changed in 2005 do making sure these 2004 rims will go
On without needing spacers thanks... Any advice is welcomed
tylerb05 is offline
post #2 of 3 Old 07-02-2012, 04:12 PM
shawnb99's Avatar
2004 should be fine, it was the coil over front end that got wider, thus having deeper offset. even the 05 up wheels can be used pre 05 , but they need at least a 1.5" spacer
shawnb99 is offline
post #3 of 3 Old 07-03-2012, 01:37 PM
Discount Tire's Avatar
Quoted: 9 Post(s)
Your new wheels should have their offset stamped into the back of them. My system doesn't have specs for a 2004 F250 with 18" wheels so I can't tell you if they'll fit. If they are off a 2005 their offset(+45mm) will be too high to run on your 2003 without wheel spacers. Discount Tire doesn't recommended the use of wheel spacers.
Low Prices! More Choices! Trusted Experts!
At The Store:
To Your Door:
Sales and Technical: 1.888.459.4080
Useful Links:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Discount Tire is offline
