Wheel Stud Issue, Need Help BAD - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 06-21-2012, 02:55 PM Thread Starter
Smoked-Silver's Avatar
I've been getting a weird squeaking noise from my front right tire for the last week or so and i thought it was the wheel bearing going bad so i jacked the truck up so i could shake the tire to check the wheel bearing and the tire was extremely extremely loose, the lug nuts had not been correctly torqued down the last time the tire was taken off which was when I took it in for brakes. my problem is that the wheel studs have now popped out of the backing plate so the splines no longer hold it still. so every time i try to take the lug nuts off the entire stud moves so i cant even tighten the lugs down or remove the tire, does anyone have any suggestions for getting the tire off so i can fix this? any help would be hugely appreciated
05 Super Duty F250 Powerstroke
5 inch lift, 35x12.5r20 Toyo M/T's
SCT Livewire, ARP head studs, EGR delete
4 inch turbo back straight pipe
Smoked-Silver is offline
post #2 of 8 Old 06-21-2012, 02:57 PM
kingranch250's Avatar
Try get set of small vise grips on the back and pull the lugs off probally have to turn the wheel all the way to right might have enough room
auto merter gauges,03turbo,volant intake,SCTcustom tunes,Harley headlights,recon smoked tail/3rd break,5 inch exhaust 8inch stack,billet grille,jessejames lawsless 20's 33"mud grapplers, jesse james door handles,arp head studs,oynx gaskets,upgraded banjo bolts,river city egr delete kit,air dog 150, 08 tailgate,all lights led,mp8
kingranch250 is offline
post #3 of 8 Old 06-21-2012, 03:36 PM Thread Starter
yeah i tried that but the rotor is too close to the wheel and i cant fit vise grips in between
post #4 of 8 Old 06-21-2012, 04:25 PM
Umm can u get small pry bar in Bwteen and pry on back of the stud put a little pressure on it n try takin it loose or small flat head
post #5 of 8 Old 06-21-2012, 07:08 PM
44magnum's Avatar
Quoted: 2 Post(s)
Can you get a nut splitter on the nuts? Or use an air hammer and split the nuts?
[FONT=Verdana][I][B][SIZE=2]2008 (Job 1) F250 King ranch 4x4, snow plow prep package with 2.5 level. Black Maxx, B&W Diehard platinums. Dieselsite coolant and transmission filters, NCU Motorsports/amsoil oil bypass kit. Turbo blankets, 5.5" blocks & PMF "floating" traction bars
44magnum is offline
post #6 of 8 Old 06-21-2012, 07:14 PM Thread Starter
might be able to do that, but theyre the XD armour rims and the lugs are set pretty far back in the rim dont know if it would fit in there, thanks for the ideas, i've been trying all day to get the damn thing off haha if worst comes to worst i might just have to drill the studs out to get the wheel off since im probably going to have to replace the studs anyways
post #7 of 8 Old 06-21-2012, 07:35 PM
Def replace the studs if there loose like that don't take any chances
post #8 of 8 Old 06-21-2012, 09:45 PM
44magnum's Avatar
Quoted: 2 Post(s)
Humm.... How much slack do you have? Can you get a hacksaw or long sawsall blade and cut the lugs between the rim and the hub? How did you plan on drilling out the studs? Hold the nut with long socket and a pipe wrench then drill out the stud?
44magnum is offline
Tags
stud , tire , wheel
