Sponsored by Discount Tire |
Can factory 08-12 wheel fit my 04
some say yes some say no, i really want to put a set of newer model wheels and ditch the small 16's, any help would be greats thanks.
Yup I got 08 20s on my 04.
you will need spacers though.
how much of a spacer
i want a set on mine as well, how much of a spacer are we talking?
I am running a 2 inch hub centric spacer set of eBay. Over a year on them with heavy towing too and no problems
did you have to run the 2in, and did you have to have them on all 4 wheels.
Yes and yes. The 05 and up have wider axles that required a different back space (off set) to keep the wheels under the truck.
figured thanks
With no spacers they hit all the brake lines. I had read that the offset difference is 2 inches so that's what I bought. If you buy less than 2 inches you will have to cut all your oem wheel studs. I didn't want to cut studs. The wheels look like the factory did it. They are out just right, not too far out or in.
