Sponsored by Discount Tire |
Does anyone know what the volume of the Brake booster pump is for the Ford Power Steering Brake System is?
Can you tell me What the pump pressure is at 500 and 1800 RPM?
if youre looking for fluid quantity, mine held just over 3 quarts of ATF.
gb |
Yep it is called hydro boost and runs off of your power steering pump and it does take ATF not power steering fluid. The volume is as stated above. I had an issue with mine some time back and if it is leaking go to your dealer and get the .17 cent washers and replace and retighten the fittings. you will loose some fluid and introduce air into the system, but just start it and turn the wheel lock to lock a few times and it till work the air out. That is what I did anyway and it worked just fine.
the resivor tank is not an issue for me. I looking for only pump preformance information |
