37x13.50x18 Toyo MT air pressure? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 05-07-2012, 06:55 PM
I just put some load range D Toyo MTs on my lifted 2004 SD. What kind of air pressure is correct? I started at 43 all around. Old OEM stock load range E tires had 60 in front and 70 in rear. Should I run less pressure in the front like OEM? Trying not to wear them out quickly. Thanks
Sent from my SPH-D710 using AutoGuide.Com Free App
Old 05-07-2012, 10:46 PM
What is the tire rated for? Around 50psi? If so that is what I would run them at....
Old 05-08-2012, 03:19 PM
Toyo tires
Yes, they are 50psi max tires.
