2012 wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 05-04-2012, 07:01 AM Thread Starter
2012 wheels
Hey guys a buddy of mine is selling Me is factory 20in wheels of his 2012 truck I'm woundering if they would fit my 2005 f-250 or I'm going to need a spacer and if I do what size spacer....where's a good place to purchase some slavers if I do need some..
JOHNNYBUSA is offline
post #2 of 8 Old 05-04-2012, 07:56 AM
RTR stroker's Avatar
They should fit no problem. My buddy has an 05' with 2010 20s on his and no spacers with no problems and they should be pretty much the same.
T.J.
- 2004 F250 FX4 crew cab -
* 4" MBRP straight pipe TB 5" tip
* "blue spring" upgrade
* 6.4 banjos
* A pillar triple gauge pod (egt,boost,trans temp)
* 2" leveling kit
* 35" yoko's
* 05' headlights(soon to be front end)
* 08' Taillights
* CCV reroute
* EGR Delete
* Sinister coolant filter
* Riff Raff boots
* Rotella T6
RTR stroker is offline
post #3 of 8 Old 05-04-2012, 11:29 AM Thread Starter
R u sure they would fit without spacer....cause I want to install them already ...
post #4 of 8 Old 05-04-2012, 12:22 PM
TheFordman87's Avatar
No they don't need a spacer. They will fit just fine. if you had a older truck 99-04 you would need spacers. But since you have an 05 with the coil spring setup you will good to go.
I'm addicted to diesel and I step on it constantly!
TheFordman87 is offline
post #5 of 8 Old 05-04-2012, 04:53 PM Thread Starter
Hey thanks.....
post #6 of 8 Old 05-04-2012, 05:26 PM
Monster07's Avatar
I will also confirm, my friend has an 06' w factory 20" and no spacers..
2007 F250 6.0
8" Fabtech lift w Radius arms.
20x12 Fuel Throttle Black
Adjustable trac bar
37/13.50/20 Toyo Open Country Mud Terrain
Amp Powersteps
5" exhaust
Monster07 is offline
post #7 of 8 Old 05-10-2012, 05:35 PM
snox700's Avatar
I'm looking at a set of 2012 18x8's. Do you happen to know what size spacers I would need for my 2004?
2004
F-250 Lariat CCSB: Many things to come...
"Your gasser was delivered on the back of a diesel."
snox700 is offline
post #8 of 8 Old 05-11-2012, 09:33 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
We sell U.S. Alcoa 6061t6 billet aluminum, Lifetime warrentee, hub-centric and wheel-centric The spacers are roughly 3-5 times stronger than the Ford cast 20" wheels .
2" spacers will work without needing to cut off your existing wheel studs but will result it the wheel moving out more as this will change the back space to 3.75"..rather than 4.5" thats stock.
We can get you 1.25" spacers but you will have to trim the studs shorter. But the back space with then be 4.5" and the rim will set like factory.
PM me if I can help.
CT Performance, Inc. is offline
