Brake Caliper Guide Pins - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 11-18-2011, 12:04 PM
During a recent service on my brakes I noticed that one of my caliper guide pins was frozen in its bore on the brake pad frame. I noticed the other three had grease on them when I removed them but the one did not.
Does anyone know what type of grease or other lubricant I should be using when installing new guide pins? I used a high temp wheel bearing grease but the caliper pins with the rubber bushings on the ends seemed to bind up really quickly with the grease on them. I cleaned them off and used some motor oil but they still seemed to bind up.
Any thoughts, comments or suggestions would be helpful.
Thanks in advance.
Old 11-18-2011, 01:26 PM
I just used some of the packets of caliper grease from the auto parts store.
Old 11-18-2011, 01:40 PM
U should use caliper grease. I picked up a little bottle at napa since I plan on lubing mine a few times a year. I don ever want them to sieze up again. It was a pita getting them out.
Sent from my fone.
Old 01-21-2012, 01:59 PM
I have used all kinds of grease on those pins. To date I have found nothing works well. We just replace calipers and carriers when they start to seize and they a good for quite a while. Sorry no mileage figures.
