Shifting feel when braking - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 10-06-2011, 12:05 PM
Not too sure on whats going on I think its just that I need new brakes. But when I step on the brakes everything is smooth and it stops good but as soon as I let up of the brake from a stop it feels like a shifting of the axle/bed/frame something to that affect from the rear of the truck. I was thinking its probably just sticky brakes that need some cleaner or to be changed.
Old 10-07-2011, 05:33 PM
I think I know what you're talking about. I don't know what causes it, but I have a similar feeling going on. I notice mine when I go to stop. Once the truck stops you kinda feel a slop somewhere, and feel it again when I let off the brakes to accelerate.
Old 10-09-2011, 11:49 AM
Check the slip joint in the driveshaft, mine did this and was fixed when I re-greased the splines on the slip joint.
Old 10-13-2011, 07:50 AM
What kind of grease did you use? I've heard its best to get it from Ford because it doesn't break down under heat and run out.
Old 10-13-2011, 01:57 PM
Greasing the Slip Joint on the driveshaft. - Competition Diesel.Com - Bringing The BEST Together
Old 10-14-2011, 06:13 AM
Sweet! Thanks for the link.
