35's on stock 17's - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 09-23-2011, 02:07 AM
35's on stock 17's
I'm going today to look at some 35-12.50-17's for my 05 f250. I need to know if they will fit my stock 17' wheels.
Thanks
Old 09-23-2011, 01:38 PM
I just put that same size tire on a 17x8 wheel but I'm not sure what the width of the stock wheel. Hope this helps
Old 09-23-2011, 05:19 PM
Stock 17" is 7-1/2" wide. 12-1/2" wide tire will be pretty wide for that narrow of a rim.
Old 09-23-2011, 05:29 PM
Send a message via AIM to FastFocus
i had a set of 315/70R17 BFG A/T's on stock 17" rims. They measured out to about a 34.5x12.4 i think. I would personally recommend a wider wheel, as you'll have to lower tire pressure to make sure you get an even contact patch. However, they will fit.
Old 11-08-2011, 02:51 PM
That's what I run and am planning to replace with same width tire.
