New pads not sitting correctly - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 09-11-2011, 05:14 PM Thread Starter
silversuper's Avatar
pics first, story later
see the inner pad sticking out past the rotor?
when I took the old parts out the old rotor was sitting like this and worn except for the outer lip which hangs over. I removed all the old top and bottom clips and replaced with the new clips supplied with my new brakes and put everything back correctly but as you can see it still hangs out.
the only thing I can think of is the lower ball joint on that side had some movement when i was really pulling on my breaker bar to break the caliper bracket bolts loose. No noticeable movement when doing the old 12 and 6 tire shake test.
I dont have a ton of money to throw at this truck to make it go away and would rather not ruin the new set of pads and rotors I just put on the truck.
Thoughts? Speculations?
thanks
Rich
Rich
2003 f250 4wd 6.0 diesel crew cab long bed Lariat.
119k on the clock, stock
has: tires, edge insight monitor, new ICP sensor and connector, new front pads and rotors, PMM EGR delete kit, new oil cooler, BOSS 9' plow
needs: tuner, coolant filter kit, blank check
silversuper is offline
post #2 of 4 Old 09-11-2011, 08:16 PM
Can you get the pad to sit in the correct position? If so see if the spring clips are not bent correctly...
2002 F-350, was a DRW, now a SRW (but kept the dana 80
ARB's front and back, 4.88 gears on 37's
AIS, 4 inch MBRP, 38R ww2, IHI bellowed up pipes
PHP 6 Pos Chip, swamps 140 volt mod
PMF coilovers and 4 link...front and back
2008 D60 up front, 2002 D80 out back
Psc hydro assist with ported hydroboost, p pump
fifty is offline
post #3 of 4 Old 09-12-2011, 04:14 PM Thread Starter
No, I cant really move it at all. I figured this was pretty foolproof since the clips snap into the caliper bracket which bolts on. could the caliper bracket be bent or something?
Rich
post #4 of 4 Old 09-16-2011, 07:47 PM Thread Starter
I hate to bump, but its kinda important
Rich
