Sticking brakes - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 07-02-2011, 07:40 AM Thread Starter
fordguy_1's Avatar
Sticking brakes
I replaced my front brake pads 8 months or so ago and I also put on new calipers. Brakes are wicks and the calipers are Autozone. I noticed at that time the passenger caliper had been sticking and now I am having the same problem again. Unfortunately I had to bleed the brakes myself so that may be part of the problem. I did not replace the black rubber brake hose, could that cause problems??
fordguy_1 is offline
post #2 of 6 Old 07-03-2011, 07:59 AM
Quoted: 51 Post(s)
I suspect it's not a hose or bleeding issue, but rather the caliper bracket slide pins. They are notorious for sticking on these trucks due to dirt and rust. When you did your brake job did you pull the pins from bracket and clean and lubricate them? Were the rubber dust boots on the pins intact? If your brakes haven't worn too much due to sticking, there's probably still a chance to pull it apart and check/re-lube/replace the pins (or possibly the entire caliper bracket) before the new pads and rotor are damaged.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 6 Old 07-03-2011, 08:04 AM
dalton1's Avatar
It is most likely you just need to grease the caliper slides and also make sure the pads can move freely on the caliper bracket.
It is possible for a rubber brake hose to cause a sticking brake but not common.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #4 of 6 Old 07-04-2011, 08:02 AM Thread Starter
fordguy_1's Avatar
I am fairly sure that the caliper kit came with new rubber boots for the pins. I did grease them but maybe too much, although I would think this would happen far more often than it does if that was the case. I will pull them apart later this week and check everything as well as replace both brake hoses.
I will post here when I am finished. Thanks for the help guys!
post #5 of 6 Old 07-05-2011, 05:18 AM
SS4Matt's Avatar
I just recently replaced the front pins on mine, I don't think they were sticking, but when I pulled them apart, a few didn't look too good. Quick/easy job to do and may very well be the cause. You might have too much grease in there causing a "hydraulic" lock situation where the pin can't slide freely?
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #6 of 6 Old 09-06-2011, 02:48 PM
I just had my brakes done and it feels like on my truck the brakes are locking or sticking . There is no rhyme or reason, first one side then the other with the steering wheel jumping in my hand from side to side. I told the mechanic what is happening and he has no idea what I am talking about.
JLimb is offline
