Stock Wheel Fitment - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 06-30-2011, 05:21 AM
Stock Wheel Fitment
Will all F-250/F-350 wheels interchange? If not what years work? My 95 has the steel ones and We used to have a 97 with the polished ones. Hope they fit. But also will the 00 and up trucks fit the 90's trucks? Thanks.
Old 06-30-2011, 04:49 PM
Superduty trucks switched to a metric lug pattern. All OBS trucks shared the same 8 on 6.5 lug pattern so they will interchange. The superduty wheels changed offset when they went to coilsprung front ends (05 up) they can be swapped with the older trucks (99 to 04)if you use a spacer. I think those are correct superduty yrs but I might be off on them the OBS info is correct though.
Old 06-30-2011, 06:22 PM
Thanks for the good info. exactly what I was looking for.
Old 07-01-2011, 01:24 PM
Let's go B's!!!!
Feedback Score: 5 reviews
All fords up to 99 is 8/6.5 same offset
All superduties 99+ are 8/170
The offset did change when they changed suspension 05+
99+ duallies are also 8/170 BUT in 05 and 06 only some were 8/200mm
2011 duallies are 8/180 IIRC.....that might be chevy idk
Old 07-02-2011, 10:45 AM
Thanks again for the usefull information. Now to see if I can find some polished aluminum stockers to fit my 95.
