F450 landscape dump truck tires - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 06-20-2011, 06:00 AM
It's time for new tires on our '06 F450 landscape dump truck. Currently it's got Double Coin RT500s (12 ply) on the front and Dynacargo DY512s on the back (all 6 tires are 225/70R19.5) Was curious as to why there are diff. tires on front vs. rear as the tread patterns are similar so I wouldn't think it's for grip (truck isn't 4wd).
A tire center nearby recommended the Sumitomo ST718 Rib tires, similar size. Are these tires any good? Also, they said they don't balance the rear tires on a dually, yet we're supposed to rotate them. That doesn't make any sense. Any other tire suggestions we may consider for installing on our truck? Weight limits (min. 12 ply) are most important as our trucks are routinely overloaded w/ stone, bricks, & wood chips.
Note: just went by the Ford dealership and looked at all their landscape dump trucks in the lot (about 15 of them) and they all had Continental HSRs (front) & HDRs (rear) so maybe those are a possibility. Anyone had experience w/ these tires?
Old 06-23-2011, 08:02 PM
I would go toyo m143 on the fronts (steers) and toyo m608 on rears (drives). 143s are a closed shoulder ribbed designed for steer applications and the 608 is a traction that performs really well. thats what I run on my route truck. Toyos are kinda spendy but theyre worth it. Great tires both are available in 14 and 16 ply if your concerned about weight. Hope this helps. Btw id probably go double coin over sumitomo. and Yes it is common to run different tread patterns on front and rear
