Sponsored by Discount Tire |
05-07 20's on a 2WD 99-03 PSD
I am getting a set of 05-07 KingRanch 20" wheels, and want to put them on my 2000 2wd Excursion.
What parts will I need to change to get the offset right, and to get the bigger brakes? For the front will I need just the calipers and rotors, or will I need the spindles too? For the rear will I need just the rotors and hubs, or will I need the whole rear axle? |
Just an added note: The rims I am getting are without tires so I wont be needing to lift it. My truck is 2wd and I like it not so tall so I will be buying new tires for the 20"s that will match my stock 265-75-16"s height.
2" spacers/adapters unless you REALLY like the look of the railway trucks.
I'm not a fan of spacers or adapters. My definition of a good time doesn't include a wheel passing me (at least not anymore!) To clarify, the wheels will physically bolt up, but will sit inside the wheel well quite a bit, and the fronts will rub the leaf spring when you turn. |
I do not want to run spacers if I don't have to. My plan is to swap over to newer suspension/brake parts to get the added width I need.
My question is: Exactly what parts will I need? If I had a whole 05+ truck for parts I would have no questions. Keep in mind this is a 2 wheel drive. |
What do I need to upgrade to 05+ larger brakes?
Maybe I should ask this a different way, see above^
you need the spindles/bearings in the front, and the entire rear differential. Not sure where you are located, but I have a 2005 rear differential, along wit the complete front suspension.
And new lug nuts if you change the suspension parts, the newer trucks have a different pitch and are metric vs american
I am in North Florida.
What would you want for the front: Spindels, Rotors, Calipers? I can get a complete rear end localy, but the front wont work because it is 4x4. |
ahh-Well, Id have to ship them. Biggest thing would be seeing how much of your old stuff you want to re-use-IE calipers/rotors. I know the 05-up are substantially larger. I could ship them UPS freight, or individually via UPS. Send me an email
dazdillenger84@gmail.com 68k miles on everything, great shape. |
I don't know exactly what I need. Please PM me a price for everything: Rotors, Calipers, Spindels.
