Air Pressure Sensors in new wheels not working - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 04-30-2011, 08:56 PM
I had my sensors removed and put in my new wheels, but the light is still coming on. I have 37x13.5R22 Toyo MT's with 65 psi. Do I need to had more air or will they not work since the factories are 80 psi max?
Old 04-30-2011, 09:04 PM
spool up that turbo!!
if you still have your stock spare tire just have all of your sensors thrown in there and they shouldnt ever go off again just my
Old 04-30-2011, 09:55 PM
^^^^^ Wrong.
Yes, the tires need to be at the factory door sticker pressure for the light on the dash to go out.
Old 04-30-2011, 10:10 PM
Originally Posted by WildStyle View Post
^^^^^ Wrong.
Just sayin it works
Old 05-01-2011, 07:10 AM
I put 65 psi in all four as required. Maybe it takes a little while to go off. I remember someone saying that thr tires have to be rolling for it to be able to pick it up so putting it in the spare may not solve it. But again I may be wrong.
Old 05-01-2011, 09:09 AM
Let me rephrase that it worked on a Chevrolet my bad fords systems may be different
Old 05-01-2011, 11:54 AM
Tire Pressure Monitoring System (TPMS) Pressure Sensor
The SJB monitors the air pressure in the 4 road tires with tire pressure sensors. The sensors transmit radio frequency signals to the SJB approximately every 60 seconds when the vehicle speed exceeds 32 km/h (20 mph).
The tire pressure sensors are battery operated and are mounted to the valve stem.
^^^^ right out of the shop manual
