Sponsored by Discount Tire |
2004 F 450 Torque specs
I was wondering if anyone might have the torque specs for a 2004 F 450 W/rear disk brakes
Rotor to hub bolts Axle bolts Caliper mounting bracket bolts And the big nut that holds the rotor/hub assembly on the the spindle Ive done some searching for theses torque specs and found some of the torque specs. Rotor to hub 94 ft/lbs caliper pin bolts 41 ft/lbs axle bolts 98 ft/lbs Just thought I would put some of the torque specs I found to check for accuracy. I did find some variations on the torque specs on the rear disk brakes. If anyone has the the torque specs for the caliper mounting bracket bolts i would really appreciate the help. |
