Hydro-Boost Replacement - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 04-23-2011, 08:39 AM
Has anyone replaced their Hydro0boost? I am in process of switching it out. I have everything hooked back up but i need to bleed system which requires cranking engine without starting it! I dont know how to keep my 7.3 from starting!!!
If you let it start it blows the "O" ring seal at the hydro-boost....oops
Any help is appreciated.
Old 04-23-2011, 08:41 AM
Illiana Chapter Director
What year truck?
Old 04-23-2011, 08:58 AM
2002 f-350 7.3
Old 04-23-2011, 09:01 AM
Pull the #30 fuse. It powers the PCM and won't let it start.
Old 04-23-2011, 09:04 AM
Thank you! I appreciate the help!
Old 04-23-2011, 09:06 AM
No problem. Instead of pulling that fuse, you could pull the one for the fuel pump but I don't know what number that is. The owners manual will tell you if you have one.
