Brake lights don't work but fuses not blown - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 8 Old 04-12-2011, 06:19 PM Thread Starter
tfifeco's Avatar
I was wondering if someone could give any suggestions. I know electrical problems can be a real pain ... but
I have a 2002 F250 Diesel 7.3 2WD
Brake lights don't work. not sure when they stopped working but couldnt have been more than a couple months. Tried changing the Brake switch at the brake pedal but didnt correct the problem. Checked all fuses on the fuse panel and everything tests. Checked every fuse with a fuse tester.
Does anyone have a diagram that labels what fuse goes to what?????
Any suggestions would be appreciated
tfifeco is offline
post #2 of 8 Old 04-13-2011, 07:21 AM Thread Starter
tfifeco's Avatar
Suggestions Anyone?
Can anyone offer any thoughts???
I have double checked all of the fuses again and they are good. I have done some research and on the Relay's and do not see a Relay for the Brake Lights, only see relays for Anti-Lock Brake, Trailer Tow and other things not related to brakes.
Again i have replaced the Brake light switch that connects to the brake pedal - When i press the brake pedal i do not hear or feel any clicking - if there is a relay for the Brake lights can anyone help determine which relay it is?
All other lights work - when i connect my boat trailer the lights come on like normal but the Brake lights on the trailer dont work either
Thanks in advance for any suggestions anyone might have
tfifeco is offline
post #3 of 8 Old 04-13-2011, 07:38 AM
Conservative and Proud
Banshee34's Avatar
Quoted: 8 Post(s)
I've got the fuse diagram somewhere on my computer.... give me a few to find it for ya!
2001 F350, Lariat SC LB 4X4 PSD
Quadzilla Commander
Zoodad with Stealth Screen
The Org. Staff reserves the right to move, modify, delete or merge posts at our discretion and without explanation.
Banshee34 is offline
post #4 of 8 Old 04-13-2011, 07:41 AM
Banshee34's Avatar
Quoted: 8 Post(s)
Quadzilla Commander
post #5 of 8 Old 04-13-2011, 08:32 AM Thread Starter
tfifeco's Avatar
Banshee34, thanks for the post
yeah, i did find this diagram and reviewed it but all of my fuses check out and the Relays listed in the diagram do not specify anything about Brake Lights, unless i am complete overlooking something.
Other than the Fuses, Relays and the Brake Light Switch, What else is there???
thanks again
tfifeco is offline
post #6 of 8 Old 04-13-2011, 08:54 AM
Banshee34's Avatar
Quoted: 8 Post(s)
Besides possibly a short, I don't know.... so.....
Quadzilla Commander
post #7 of 8 Old 04-17-2011, 08:30 AM
eberlestock's Avatar
Quoted: 6 Post(s)
I had this problem on an 04 company truck. Took it to the shop and it was some sort of switch in the steering column. Cost about $200 to fix.
2008 F350 6.4 diesel lariat
8" suspension, bilstein remote resovoirs
traction bars. buckstop bumper, 12k smittybuilt winch. Led driving and fog lights. HID headlights
deleted, tuned, intake, exhaust, intercooler, studded
power amp steps
Build in progress
eberlestock is offline
post #8 of 8 Old 04-22-2011, 10:20 PM
could possibly be the multi function switch in the column, take the covers off of the column and bring it up to autozone and ask if theyll let you just switch the multifunction switch out to see if thats whats wrong, its only two screws after you have the covers off. do your blinkers work?
mpiller is offline
