what mods to change to late wheels - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 3 Old 04-07-2011, 04:53 PM Thread Starter
Question what mods to change to late wheels
i have a 02' f350 lb cc 4x4. wanting to change to later model(08 and up) 20" wheels. i know the bolt pattern is the same. but what about the offset? what changes besides spacers (i need to know spacer size). studs, lugnuts, etc. what all is involved with changing to later wheels?
thanks in advance
95hawk310
95hawk310 is offline
post #2 of 3 Old 04-07-2011, 05:27 PM
From as far as I can tell, you can run them as is, just the wheel will be sucked in a bit. f you run wide tires, you will rub on the leaf springs. You could also get spacers and that will push them out a bit so they will look right (On the pics I have seen they look alright with out spacers) and you can run the wide tires...
I believe the backspacing is a little bit more than an inch deeper on the newer wheels. Don't mark my words on that one because I have never measured.
2002 F-350, was a DRW, now a SRW (but kept the dana 80
ARB's front and back, 4.88 gears on 37's
AIS, 4 inch MBRP, 38R ww2, IHI bellowed up pipes
PHP 6 Pos Chip, swamps 140 volt mod
PMF coilovers and 4 link...front and back
2008 D60 up front, 2002 D80 out back
Psc hydro assist with ported hydroboost, p pump
fifty is offline
post #3 of 3 Old 04-07-2011, 08:27 PM
I'm running LT275/70R18 GY duratrac's on my 18" Incubus Crusher wheels with 5.5" back spacing (pretty much the same as the 05+ wheels) and they do not rub the springs at all. I have about 1/2" of clearance at full lock.
1991 Ranger - 38" TSL's, 3 link, One tons, 5.38s on King air shocks....under construction.
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 31x10.50r15 MT's.
2008 F350 - Crewcab short bed, 6.4L diesel, H&S XRT Pro, AFE DOC/DPF delete
1972 Mustang Coupe - 302, c4, 9", 4.11's locked.
WildStyle is offline
