Sponsored by Discount Tire |
DRW tire position questions
replacing the 4 tires on the rear of the truck Wednesday. Should i take the 2 front tires (they have about 6-8000 miles on them) and put them in the rear and put a set of brand new tires up front?
This will be my first time replacing tires at different times. This will be my first time replacing tires at different times. i put 6 new 315/75/16 nitto tera grapplers tires on the truck when i bought it. Ended up replacing the front two nitto tires with BFG AT's due to bad ball joints which ate then up while i was deployed. That is why I am replacing the rears (nittos) with new BFG AT's I hope that makes sense. Last edited by needatruck; 03-28-2011 at 04:00 PM. |
If it was me, I would put them on the back (inner wheels) and put the new ones on the front. The rears will far out last the fronts.
I agree with BigBlue
I would do the same, the inner rear's wear the least. That's my experience, as I replace things in pairs. Shifting the BFG fronts to the inner rears allow you to avoid replacing the fronts again as quickly as you would otherwise.
cool sounds good guys thank you for the information!
