ABS Control Valve Help - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 03-23-2011, 10:29 AM
I believe I need to change my ABS Control Valve in my 97 f-250. From everything I have read I believe I have found what is causing my brake issues. My question is how do I go about changing one? I have done the usual stuff, pads, shoes, rotors, drums and bled the lines but this is new territory for me. Is there anything I should be aware of or certain steps to follow while changing it? Will I need to to re-bleed the brakes after the install? Any help is appreciated
