Sponsored by Discount Tire |
06 leveling kit and new tires! Best size???
i want to put some new skins on he factory wheel..... now i just need to decide what tire and size to do..... also 2.5" coils spacers??? i want it beefed up a bit and i will be plowing next year aswell!
help me out |
I'd get the Ford snow plow package front springs..should get you 2", then run 35" Add castor shims.
ok.... from what i saw online i would need to one up my front springs?? so go from the 6000 to 6500?? that will give me 2 inches? and what are castor shims?? im not a suspension guy thanks in advance
also where is the best place to get the springs??
Ford has 7klbs front springs..best place.
so could you just change the springs and get it aligned? or are additional parts needed? will the shocks fit?
I always thought the 6000lb springs were the plow prep springs.My driver side door sticker says 6000lb front gross weight....I could put 7000lb springs?
Im also curious about this topic...subscribed
AA — 5C34-5310-AMD, 7,000 lb
BB — 5C34-5310-ALD, 6,500 lb CC — F81A-5310-AHD, 6,000 lb DD — F81A-5310-AGD, 5,600 lb Someone may have additional info. |
