Sponsored by Discount Tire |
rim question
will rims off of a 05 f350 fit my 00 f350 I need to take of my 20 inch rims and 42 km2's and go down to a 17 inch rim to fit my 47 inch growlers. I found a good used set of welds off of a 05 just wanna make sure they will bolt on thx guys.
It depends on the backspacing of the rim.
Stock 17" rims won't fit because they have too much backspacing (about 5-3/4") and will hit the tie rod ends. If the 17" rims you are looking at have 4-1/2" or less backspacing then they will work fine! And the bolt pattern is the same for both, so that is not a problem. |
I think the factory backspacing is 4-1/2", so 5" will probably work but I am not 100% sure of that.
It would be best if you could trial fit one on the front of your truck just to be sure, watch the clearance between the edge of the rim and the tie rod end. |
