Sponsored by Discount Tire |
2012 F-350 tires & wheels
Okay, going to order 2012 F-350, 4x4, crew cab, long bed. Looking to get tires and wheel thinking about BFGoodrich All-Terrain T/A KO LT325/60R20/E, Need to find rims that will support this tire. Need to wide enough to support this tire and have the weight rating as well. Local shop's not much help - small town.
depends on what kind of look your going for
also do you plan to lift it |
Going to be towing 5th wheel with all the toys in it. I tow on the beach veyr soft sand. I need to air down the tire to get max traction on the sand. Want to keep the speed-o about the same. Local shop's no help on recaling the speed-o so for over all tire dia. want the keep this about the same. just want a wider tire that works good in the soft sand has a load range of "E" very hard to find.
Im pretty sure that ford can fix your speed-o to a 35" tire, anything past that youll needa tuner of some sort to do it. Also since you will be running on soft sand your probably want a wide tire. If i were you i would level it out and get some 33x13.50's with a 10" wide wheel with 4.5" backspacing.
