4x4 Issues - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-08-2011, 02:31 PM
4x4 Issues
My Dad's '96 F-250 Dully won't engage 4wd. Shift into either setting the light comes on but the front tires won't engage. The only thing I have yet to check is to see if the front drive shaft spins. The hubs are electronic as far as I know and I didn't see any vacuum lines for the diff. any thoughts? If we need new hubs where is the best place to pick up a new set?
Old 02-08-2011, 02:43 PM
Illiana Chapter Director
The auto hubs in those trucks work off of centrifugal force. The axle has to rotate before they will lock. I've seen many of those blow apart internally because they get locked in after the truck is already stuck. They lock it in and the rear tires will spin and when the hubs try to lock, it breaks the ears off inside.
Old 02-08-2011, 02:45 PM
So if I try again while its rolling and they still don't engage, they most likely are toast then?
Old 02-08-2011, 02:50 PM
Yeah. You need to be rolling slightly when you engage them. I had a guy come in to the dealership I use to work at with a set blown apart. We put a new set in, he went home and hooked to his 5th wheel, started to back up and the rear tires started to spin. He stopped and locked it in but when he started to back up the tires started to spin again and the the hubs locked in. Blew the brand new, 1 day old hubs to pieces. He was back at the dealership the next day buying another set. If yours are bad, you're better off installing manual hubs. If you go manual, you also have to replace the nut kit (retaining kit) because it is different than the auto nut kit.
Old 02-08-2011, 03:20 PM
I'll give that a shot then.
Old 02-09-2011, 12:18 PM
The drive shaft is turning the axles are turning and the front wheels don't spin when we get on it in the snow. I take it as the hubs are blown. So any good suggestions on replacements for a good deal?
Old 02-09-2011, 12:24 PM
Just get a set of warn premium manual hubs and new nut kit. Only option for auto hubs are the original ones.
Old 02-09-2011, 12:28 PM
Those manual hubs don't need a conversion kit at all?
Old 02-09-2011, 12:30 PM
The nut kit IS the conversion kit. There is a nut kit for manual hubs and a different nut kit for auto hubs.
Old 02-09-2011, 12:35 PM
Oh got ya. Its a its a learning experience for me. I'll check it out. Thanks guys.
