Would these rims fit with the bs/offset? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 02-06-2011, 12:08 PM
Question Would these rims fit with the bs/offset?
I am looking at some rims that are 4.75" backspace with -6 offset and will be putting them on 35/12.50 R17 tires. I have a level kit and plan to go to 4" lift soon, just wondering how these would rub with the level kit and the lift kit. Going on truck in my sig...
Old 02-06-2011, 12:56 PM
I think 35's will be a problem without a lift. If not, it'll be really close.
I'm subing this one because I'm curious about the 4.75" BS also. We should be fine with anything between 4-5" BS but I think tire size will also make a difference as the BS increases, especially with 12.5's.
Old 02-08-2011, 11:44 AM
Sorry to hijack your thread but will 20x11 rims with -24 offset and 35's clear with a 6" lift? How do I figure out how much backspacing that is?
Old 02-08-2011, 01:18 PM
Leveled you will rub the plastic inner fender at full lock, 4" lift you should clear
Old 02-08-2011, 02:01 PM
Wheel width + 1. 11 + 1 = 12
12/2 = center of wheel 6"
6" + offset = backspace. So, 6 -24mm (almost 1") = a shade over 5" backspace.
