What do you think of these wheels? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 02-06-2011, 08:57 AM Thread Starter
Send a message via Yahoo to skipnay
Hey guys can you tell me if the offset is wrong with these wheels and/or what will the offset do? So tell me what offset would be best and while your at it tell me what you think of these wheels?
Wheelsforless - Custom Wheels - IO179-8970B - 179 18x9 8/170 - Truck & SUV Wheels - Wheel Specials - Wheelsforless
2010 My Wife has 2 Full time JOBS NOW
2008 F250 H&S MiniMaxx, S&B CAI, and cat/pdf delete
2008 Brute Force 800 All hooked up 67hp to the wheels
2007 Got Married
2004 KFX 700 Stock Bore Kit XX cams
1990 Mustang Notch getting ready to hook it up
1988 Mustang GT 449hp to the wheels 6sp Getting a cage installed
skipnay is offline
post #2 of 4 Old 02-06-2011, 01:05 PM
Depends on what truck. The link you included is to a wheel said to be for '98 and up F250 but in '05 BS changed. 5.5" BS is a little too much though, for anything prior to '05 but might be OK for '05 and up.
JKTex is offline
post #3 of 4 Old 02-07-2011, 02:47 PM Thread Starter
It's for my 08
2007 Got Married
skipnay is offline
post #4 of 4 Old 02-07-2011, 09:13 PM
I think it would be ok. Depending if your leveled out and what size tire you are running you might rub a touch at full turn. It will probably hang the tire out just a touch past the fender. I am leveled 2" in the front with a 20x9 and a -12mm offset with 35x12.50 toyo m/t's. I only rubbed at full lock, but with a quick trim to the plastic inner fender it solved the problem.
sixleaker is offline
