'nother wheel help - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 01-30-2011, 04:55 PM
'nother wheel help
lookin at putting procomp 1069's on my 02 sd and wanna know what bs i need. searching and i cant come up with a good answer. ones i am planning are the 18x9's and plan to wrap them in a 295/65/18 GY wrangler duratrac.
thanks in advance
Old 01-31-2011, 01:55 PM
Feedback Score: 5 reviews
4.5" BS..............
Old 01-31-2011, 03:25 PM
i hate this offset b/s they have, its a 4.75 BS with a -6mm offset which if i figure this correctly does equate to the 4.5'' BS i actually need
Old 01-31-2011, 03:42 PM
It it says 4.75" its 4.75" BS..
Old 01-31-2011, 04:11 PM
then wtf is the -6mm offset for? ive never had a issue doing wheels for my mustang cause its simple. never had someone tell me a BS figure then a offset number as well
Old 01-31-2011, 04:12 PM
9" wheel with a -6mm offset is about 4.75" BS. Calc. by taking the Wheel width + 1" (for the lip) div. by 2. Take the offset from there, in this case -6mm (or about -1/4")
So
9+1= 10
10/2= 5
5 - about 1/4" = about 4.75".
I wouldn't think that would be all that bad. I guess it also depends on tires.
Old 01-31-2011, 04:25 PM
ah ok, why do they gotta be stupid with it. a simple BS number is best imo. oh well. tire im planning is a goodyear wrangler duratrac
LT295/65R18 Rim width=8.0 - 10.0
meas rim=8.50
section width in inches=11.8
height=33.1
max load @ psi=3,860 @ 80
trucks also has x codes up front so i dont see height being a issue either. im thinking i should be alright width wise on them too
