what size tires can i fit?!?!? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 11 Old 01-28-2011, 04:07 AM Thread Starter
Dont Mess With Texas!
ThirdCoastStroker's Avatar
Quoted: 14 Post(s)
i am getting a 2.5" leveling kit on my 2008 F-350, i will be keeping the stock rims so i was wondering what is the tallest tire i can run on there?
i was thinking some 305's on my stock 20's?
i will be getting pro comp extreme at
thanks in advance
Casey
New Truck
15' F-350 King Ranch 4x4 CCLB
Platinum White / Caribou Metallic
Stock for now!
Old Truck
08' F-350 King Ranch 4x4 CCSB
H&S Mini Maxx 300 HD
5" Straight Pipe to 7" rolled tip
AFE S2 PDS
ARP Head Studs
FloPro EGR Delete with Intake Elbow
FloPro CAC pipe
Rebuilt beefed up OEM Up pipes
Deisel Site Coolant Filter
Firestone RideRite Airbags
Leveled
35X12.50R20 ProComp Xtreme A/T
Ranch Hand Front and Rear Replacement Bumpers
ThirdCoastStroker is offline
post #2 of 11 Old 01-28-2011, 04:13 AM
Quoted: 36 Post(s)
that is the same thing i am contemplating. 08 f350 lb cc 4x leveled. need tires and shocks and am surfing to figure it out too
gwilkrrs is offline
post #3 of 11 Old 01-28-2011, 05:33 AM
Clayton1985's Avatar
I think we can run 35s without any lift if wanted so maybe 35s or even 37s??
Clayton1985 is offline
post #4 of 11 Old 01-28-2011, 05:42 AM Thread Starter
Quoted: 14 Post(s)
thats what i was thinking...the 305's are 36.8" tall i really wanna feel the wheel well up as full as possible but i dont want it rubbing on the bottom of my quarterpanel...the fender wells are not a big deal i can tie those back....anyone out there running them?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #5 of 11 Old 01-28-2011, 07:33 AM
TripleE44's Avatar
Pics of tires with factory 20s <----Click that.
And where are you seeing tires that are 305s wide that are 36.8 tall? They only say the 37X13.50s are that tall. The only 305 they list has an aspect ratio of 55 which is nowhere near a 36.8...
11 F250 6.7 CC/SB -- tuned & deleted -- 3.5'' PMF/ICON/Fox suspension, Method Standards, Toyo AT2s
TripleE44 is offline
post #6 of 11 Old 01-28-2011, 07:51 AM Thread Starter
Quoted: 14 Post(s)
Thanks for the link....ok, say i get 35's do you think 35x13.5 r20 on stock rim would be too wide? will it rub really bad on radius arm? should i stick with the 12.50?
what about 37's with just a level kit?
would i rub up my quarter panel on the bottom side pretty bad?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #7 of 11 Old 01-28-2011, 07:58 AM Thread Starter
Quoted: 14 Post(s)
can i even run a 13.50 wide tire on a stock 20" rim?
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #8 of 11 Old 01-28-2011, 08:06 AM
TripleE44's Avatar
All I know is my 325/65/20 Terra Grapplers rubbed the Radius arm, but it didn't cause a single problem. It would only rub at full lock, which I made it a point to only turn that sharp if I had to. If I remember right the width on those is somewhere around 13.0, and the height is almost 36''. That being said, I had enough room for 37s. The extra half inch would only take 1/4 of an inch from the turning radius at most, which wouldn't matter and you'd get the stuffed look.
Technically, no. But that guy in the link I sent you is doing it so it can be done. The Terra Grapplers and most 12.50s say they aren't supposed to work but do, and wear fine from what I've seen.
post #9 of 11 Old 01-28-2011, 08:09 AM Thread Starter
Quoted: 14 Post(s)
well the tires im going to run are pro comp extreme at...i think im just going to go with 35x12.50r20 so i dont have to worry about losing fuel economy and rubbing to much
Casey
New Truck
Stock for now!
Old Truck
AFE S2 PDS
ARP Head Studs
FloPro CAC pipe
Leveled
post #10 of 11 Old 01-28-2011, 08:24 AM
2011kingranch's Avatar
I have a 2011 F350 and ran the 325/60/20 on my stock rims with no lift and they did great. I put a Ready lift 3.5 on and aftermarket wheels with -12 backspace and they rubbed a little.
2011kingranch is offline
