Biggest tire for stock? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 01-21-2011, 07:12 PM
In need of the first set of tires. F-350 SRW
4x4 . have 20" factory rims & looking for a bigger, all terrain tire on my 2010 hot rod ford .. Thanks
Old 01-22-2011, 10:02 AM
The 295/65R20 is the largest size I would recommend for your stock wheels. This size may require some minor modifications to keep them from rubbing with your stock wheels.
Here's a set on a leveled F250 with aftermarket wheels... They rubbed at full steering wheel lock but its easy fix with leveling kit.
Old 01-22-2011, 02:34 PM
BGJ BGJ is offline
Hey Discount, can you tell me what the largest tire I could put on my 02 Super Duty Extra cab long bed? I want to stay with the stock 16 inch wheels & do not want to exceed 11.5" wide. And of course not go over 35 inches in height.
I'm no good with these metric tire sizes. BTW, my truck is leveled.
Thanks, Bruce
Old 01-22-2011, 04:44 PM
I can get a leveling kit.... That sure looks good!!
I get in & out of my truck so much and its tall already. Thank you very very much..
Old 01-24-2011, 06:27 AM
Thanks, Bruce
With the stock wheel only being 16x7" wide the largest tire size I would recommend would be a 265/75R16. This size is about 1.25" wider than your stock tire and the same overall diameter.
If you were planning on upgrading to a wider 16" wheel the 285/75R16 would be a great size to run with your leveling kit. This size is about 1" taller than your stock tire, and just under 2" wider.
Old 01-24-2011, 06:12 PM
BGJ BGJ is offline
Thanks for the reply. I was hoping for a bit taller. I guess, like a true 34 inch by 11.5. Oh well. I also forgot to mention the size I'm running right now. 255/85/16.
Thanks again.
Old 01-24-2011, 06:35 PM
I'm running 20" rims on mine!! Factory, Don't know how wide??
Old 01-25-2011, 07:18 AM
^ Stock 20" wheels are 20x8 with a +45mm offset. (6.28BS)
Thanks again.
If you like the height I'd stick with this size until you upgrade to wider wheels.
Old 01-28-2011, 03:57 PM
BGJ BGJ is offline
Thanks for the info.
Old 01-28-2011, 05:25 PM
Let's go B's!!!!
Feedback Score: 5 reviews
You can fit 37's on it with a leveling kit and stock rims. IMO it doesn't look good, but they fit. I just did it this week
