325/60/20 on a leveled 250 - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 23 Old 01-10-2011, 09:01 AM Thread Starter
jonnysteals's Avatar
I have searched and found guys runnign these on stock wheels but I need to know if these would work on my truck.
I have a 2006 250 with a 2.5 inch front leveling kit and f350 blocks. I have 20-10 rims with 4.5 inch back spacing. I also have my front valance trimmed and my inner fender pulled back. I currently run goodyear wrangler ats 275/65/20(stock tires) and want to upgrade to 325/60/20 goodyear duratracs. Will these tires rub or will I be ok. its basically a 35.5 by 13.0 tire. I hope these will fit with no rubbing and I can get ready to order a set.
Thanks in advance.
-Jon
jonnysteals is offline
post #2 of 23 Old 01-10-2011, 09:04 AM
Enterko's Avatar
subscribed
Enterko is offline
post #3 of 23 Old 01-10-2011, 09:17 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
My 33's (325/60/R18) would rub on full turn with that backspacing. I'm sure you will be trimming quite a bit of fender well in order to not rub with the 35.5's... Think, Tank and his cutting his fenders all to pieces...
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is online now
post #4 of 23 Old 01-10-2011, 09:29 AM Thread Starter
Thanks for the quick reply. My current tires are 34.5 by 11.4 so I am not worried about the height really but mainly the width. My current tires don't rub anywhere at all. The tires I want to run are basically a 35 12.50 on aftermarket rims. I really hope they fit
-Jon
post #5 of 23 Old 01-10-2011, 12:06 PM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
I guess I should have mentioned that my tires were 33x13. Mine were a bit more than 13" wide mounted on rims with 4.5" backspacing. That's one inch wider due to the wheel backspacing from where the stock wheels are. I'm hoping that it is just enough to clear.
Shawn Carlson
Proud Navy Vet
Engine Mods:
Fluidampr
4" MBRP Exhaust
MTW Stage 1 Turbo
Exterior Mods:
post #6 of 23 Old 01-10-2011, 12:35 PM
SS4Matt's Avatar
hmm... I have that size dura'trac on my 20x9 wheels, I too have 4.5" backspacing, and I rub on the leafs, I pulled the fender liners back and clearanced the valance a little bit. It only rubs on full lock so it really doesn't bother me much
02 F-250 7.3 Powerstroke PMF Suspension 20" XD Hoss 325/60R20 Dura-Tracs
38R 4" MBRP TW Chip HPX Mod EBPV delete 6637 Billet Converter Shift Kit Autometer GS
SS4Matt is offline
post #7 of 23 Old 01-10-2011, 12:40 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
He doesn't have leafs.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #8 of 23 Old 01-10-2011, 01:14 PM
SS4Matt's Avatar
ahh didn't realize it said 2006 ... well then he'll probably be better off then I
Last edited by SS4Matt; 01-10-2011 at 01:15 PM. Reason: reading comprehension took a back seat today!
SS4Matt is offline
post #9 of 23 Old 01-10-2011, 01:17 PM Thread Starter
Yea I am hoping that someone like DC can come here and say it wint rub on my radius arms and should just barely clear my inner fender. I did a little test in my driveway turned all the way and went up an incline with the wheel turned and had over an onch of clearance. I dont think the heights the issue but the width.
The only other size tire they have is a LT305/55R20 which is a 33.2 12.5 but I think that might be to small. I really need a 34.5 13.00
I just talked to my buddy he runs a 325/65/18 on a leveled superduty and it just barely rubs. thats a 34.8 13.00 tire. His wheels seem to not be as offset as mine either. Dont know if this will work or not
-Jon
post #10 of 23 Old 01-10-2011, 01:18 PM Thread Starter
hey you have any other views of the tires from the front?
-Jon
