Pics 38 x 15.5 x r20 rockstars & Kuhmo's - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 29 Old 12-23-2010, 10:07 PM Thread Starter
MONSTER_NRG's Avatar
Hey Guys,
I can get a good deal for 38 x 15.5 x r20 rockstars & Kuhmo's with 4.75 backspacing. Would this work? Also any pics of this setup or close to it. I'm not sure about the 15.5. Right now I am running 37 x 13.5 x r 18
Trucks in the sig but it has a 6" lift
Thanks
SOLD99.5 CCSB SRW 4x4 Lariat Matt@Gearhead tunes, 160cc/80% injectors, New JasperTrans w/ BTS V.B., ISSPRO Gauges, 5"MBRP, Wicked Wheel, S&B Intake, Custom Traction Bars, 6"Lift 38x15.5x r20"tires, Bilstien5100, Foil Delete, CCV & Zoodad Mod, Dual Stabilizer, etc
OUTLAW DIESEL PERFORMANCE
Black 09 SCSB 6.4 Larait Plus Fx4 pkg
MONSTER_NRG is offline
post #2 of 29 Old 12-23-2010, 10:36 PM
Sorry I cant help, but can you post bigger pic's of your current set up? I am debating 18-27's vs 20-37's
2002 F-350, was a DRW, now a SRW (but kept the dana 80
ARB's front and back, 4.88 gears on 37's
AIS, 4 inch MBRP, 38R ww2, IHI bellowed up pipes
PHP 6 Pos Chip, swamps 140 volt mod
PMF coilovers and 4 link...front and back
2008 D60 up front, 2002 D80 out back
Psc hydro assist with ported hydroboost, p pump
fifty is offline
post #3 of 29 Old 12-23-2010, 10:39 PM
Guest
xxxxxxxSTROKE_THIS_F-250 is offline
post #4 of 29 Old 12-23-2010, 10:50 PM Thread Starter
Thanks john for posting that for him. Here is a good link over on the nation with a show and tell of their set ups.
FYI Rims and tires might be for sale
http://powerstrokenation.com/forums/...ad.php?t=47051
post #5 of 29 Old 12-25-2010, 10:54 PM Thread Starter
The bs is 4.75 not 4.5 if that makes a difference.
Thanks
post #6 of 29 Old 12-25-2010, 10:54 PM
Guest
To the top, need info asap. We think it will have plenty to clear the fender, just worried about not being able to cut the wheel with out hitting the leafs with little turning span. The new wheels will actually have a 4.75 back spacing, would this be enough?
post #7 of 29 Old 12-26-2010, 09:14 AM Thread Starter
Any info guys, thanks
post #8 of 29 Old 12-26-2010, 06:18 PM
I have a 10" lift with 38x15.5 on 16s and my tires rub the leaf springs at full lock and hit the inner fender sometimes when turning and hit a bump. I cut the inner fenders and it hasn't rubbed on those lately but i don't know the backspacing or offset of my wheels. If i was to guess it was about 4.75-5. sorry i can't be of more help.
here is a pic that sort of shows how much they stick out.
Taylor
2002 EXT CAB LB
10" super lift
40" xterrains
Amp Research steps
Dipricol Optix gauges
6637
DP Tuner
4" Straight pipe
tp83 is offline
post #9 of 29 Old 12-26-2010, 06:30 PM Thread Starter
Nice rig... Thanks for the info and pic. At this point any info is good info. Probably isnt the best idea but they are a really good deal. If it doesnt fit i guess i could always sell them or someone said pro comp makes a kit to go from 6 to 8. Ever hear about this?
If i get these i would have to head out tomorrow morning guys.
thanks
post #10 of 29 Old 12-26-2010, 11:56 PM
It really depends on the kit your running now. If it was a spring kit in the front, meaning no hangers and shackle replacements you can just add those to get more lift. That is probably all the procomp kit will do. PMF or sky-manufacturing have decent hanger/shackle kits. Another thing you would have to watch for with adding to the lift would be shocks and brakelines. The shocks you have might be able to run with an 8" lift. With the 6" we put on my brothers truck his brakelines seemed almost maxed out so those most likely need to be lengthened.
If you are getting a deal on the tires/wheels its definitely worth a shot. They should fit and if needed will fit with trimming of the front plastic bumper and inner fender. A buddy of mine had 38's a long time ago on his 2wd f250 and all he had was a 6", which looked near the same as a 4wd with a leveling kit, and did some minor trimming. The tires were a little narrower. Your rig would look pretty badass with some 38x15.5on 20s under it though.
here's the link to the PMF hangers:
Front Lift Shackles and Drop Brackets - Precision Metal Fab
Taylor
2002 EXT CAB LB
10" super lift
40" xterrains
Amp Research steps
6637
DP Tuner
4" Straight pipe
tp83 is offline
