Sponsored by Discount Tire |
what do you guys do for a spare tire?
I just installed a set of mickey thompson 315/70/17 on my 2003 f250 crew cab 7.3L truck. My question is what does everyone do for a spare? Currently i have a 285/75/16 under the truck. Im assuming i could run this tire in an emergency to get me home or to a tire shop, if i put the small tire on the front. I know i deffinetly wouldnt want it in the rear. I know it would like horrible but if i didnt use 4x4 would it be causing any damage?
Also whats the largest tire i can fit on a 16in rim under the truck? Im wondering if i could squeeze a 315/75/16 under there how that would be as a spare, since it would be closer to the 17's than the current 285/75/16. Thanks for any ideas or info mark |
I took mine out, im not going to run anything on it if its not the same size, so whats the point of the extra weight.
you can fit a 35" in the stock location. Thats what i've done on all my trucks since my 99. If i was you i would just put a 315/70/17 on your spare rim and call it a day. Even on my 09 i keep a 35 in the stock location. And thats one of the main reasons i don't run anything bigger then a 35", I like a have a full size spare and not take up bed space
![]() Edit: saw its a 16" for you spare. And a 315/75/16 fits the rim just fine and fits in the stock location even with a 4" exhaust. Thats what i used on my 99 and 01 Last edited by wired1; 07-11-2010 at 04:04 PM. |
We all need a spare - for that one rare chance that one of our heavy duty tires do actually get a flat! I havent had a flat on my truck since I bought it almost 150,000 miles ago - but you never know.
As far as the height difference in the tires - the general rule of thumb is if you get a flat on the rear, put the spare on the front and move the front to the flat location in the rear. Reason is with our unlockable front axles - it allows the front to spin at different rates and not screw anything up. Do this for a short distance only. Enough to get to a facility to get the tire hopefully plugged and back on or all together replaced if your so lucky. Good luck. |
on the front as long as you didn't lock the hubs or engage the 4 wheel drive you would be fine . Even on the rear end to get a few miles would be ok , kinda like the mini spares some cars come with . That being said I wouldn't go far . You would risk messing up the clutches if your truck has a posi (limited slip) rear end . If you have an open rear end it would be fine .
i have a full size spare.
I have a full size 38 in spare. I had a mount built in the bed. My truck is pretty much as worthless as $%^% on a boar anyway as far as towing and what not so i don't care about bed space. It's my toy. I only put it in on long distances. Have not had to use it so far.
How did you guys get a 35" under there? I have tried and it ain't even close? My 4" exhaust is right up against my shock too? Hits it in fact. I still have my factory spare.
haha, how about a few cans of fix a flat?
