pulsation - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 4 Old 07-02-2010, 10:31 AM Thread Starter
pulsation
I have a 2000 Excursion 2WD. I experienced pulsation when braking so I replaced rotors and front brakes. I also broke a tie rod so replaced the drag link and drivers side tie rod. It's better now but still pulsating. I can gently ride the brake when coasting to a stop and feel it in the driver's front. Did I get bad rotors or is there something else?
frankr is offline
post #2 of 4 Old 07-02-2010, 07:36 PM
jno
Could be a bad bearing. I had a bad bearing (hub assembly) on one of my cars. I went through 2 sets of rotors, pads before I figured it out. Just an idea.
jno is offline
post #3 of 4 Old 07-03-2010, 03:23 AM Thread Starter
thanks jno. I saw a couple of other threads about hubs and bearings and was kind of thinking in that direction. I'll check it out.
Frank
frankr is offline
post #4 of 4 Old 07-03-2010, 09:24 PM
SJB
SJB's Avatar
Maybe just jack the front end up and spin the tires to see how it feels, and see if it has any side-to-side movement. Maybe that would give you an idea if there is any bearing problems.
2002 F250 XLT CC 4x4
- Isspro EV gauges (Pyro, Trans temp, Boost)
- Walker BTM Muffler
- DIY Intake w/ AMSOIL 4095 washable/reusable filter
- 6.0 Liter Transmission Cooler
- '08 Kool-Vue tow mirrors
- Tuff Country 2.5" leveling kit 22962KN
- Factory F350 blocks in the rear
- Readylift 67-2094UB u-bolt kit for the rear
- Moto Metal 970 18x10's w/ -24 offset
- Cooper Discoverer S/T Maxx 295/70-18's
SJB is offline
