Anyone run 285 75R 16" Tyres on 10" Rim - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 6 Old 07-01-2010, 09:57 PM Thread Starter
Reg Bichel's Avatar
Question Anyone run 285 75R 16" Tyres on 10" Rim
G'day Fellas, first post this forum.
So..ere goes.
Have any of you blokes run 285 75R 16s on 10" Rims?
I'm well aware of makers rim size specs for differing tyre sizes, just want to know if any of you blokes have done this and what was the result?
Was it a case of..as we Aussies say 'No worries mate or was it Don't do dat stuupid!!
I'm running Toyo OPAT AT 305 70R 16s on the 10" Rims at present as it is within Toyo spec for these tyres. No worries and I've been reasonably happy with the size and performance.
However; at my next tyre change, I'd like to come down a size in tread width without loosing diameter (33" looks better in the wheel arch than 31").
But don't want to go to the extra expense of getting 8" rims as well as tyres, and the 285 75R 16s are the same 33" Tyre due to width to wall height ratio differences.
I know it doesn't sound a lot but just the 20mm difference in tyre width x 4 wheels is 80mm (3.2") more tread on the terra firma adding to rolling resistance.
However if you take the difference between the stock 265s and you have 40mm x 4 tyres giving 160mm more rolling resistance. For you blokes, it's 6.3" of extra tread on the road above stock specs for gear changes, diff ratios ect...
I know the extra 2" in diameter will also be adding to the maths.
But with Diesel generally between US$4.30 to US$6.10 a Gal Downunder in Aussie and if you go far enough Outback it can be well in excess of US$7 a Gal. So any gain is worth at least thinking about.
Now back to my original question: Can any of you blokes see or have experienced any adverse effects put on a 285 75R 16 tyre on a 10" Rim.
I'm considering the Michelin LTX AT2:
LT285/ 75 R 16 Rating 126R (E) Dia 834mm(32.8 inch) Width 286mm(11.25 inch). Recommended Rim Width 7.5 -- 9.0".
What will that extra half inch a side (1" overall) above manufactures recommendation do to the tyre on a fully loaded truck towing a 3,300kg Trailer?
Aussie spec Brazilian built 2005 (US 2003) F-250 Superduty 4x4 7.3Ltr Powerstroke: Donaldson (AIS) Intake with Zoodad, AIH deleted, DIY CCV & catch can, 26 x 3 Cummins straight through muffler, MBRP Black Tip, Foil Delete, Old Man Emu (OME) HD rear spring set, Front leveler spring, OME Nitrocharger Dual Tower shocks front, OME Nitrocharger shocks rear, Tough Dog Steering Damper, ARB Air Lockers Front & Rear, V10 Tranny cooler in series with Stock Tranny cooler, Deep Tranny Pan, Extra Cooling rear diff cover, ARB HD Front Diff cover, ARB Bull Bar, Kymar Dual Spare Wheel carrier & Rear bumper, Edge Evo with Dash Pod & EGT pyro, Long Range Fuel Tank, OEM Style paint matched wheel arch flares, VMS in Dash GPS Street & Off Road Navigator, Toyo OPAT AT 305 70R 16 on 10 Rims.
Reg Bichel is offline
post #2 of 6 Old 07-01-2010, 10:04 PM
riddin' high
Dasaliac03's Avatar
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
it would look just fine
let see some pics of the truck!
SOLD - '03 7.3, MBRP, 38r, DP F5, HPX, RR, DIY 6637, 05 OEM Harley front, 08 OEM rear & mirrors, 20" Moto Metal, 35" Nitto's
Current - '11 6.7 FX4 Larait, Ready Lift 3.5" Leveling Kit, '13 Larait Wheels
Dasaliac03 is offline
post #3 of 6 Old 07-01-2010, 10:25 PM
kosk0100's Avatar
I am running that combo right now until I upgrade to 315's. I have Dick Cepek 16x10's with the 285/75R16 brigestone tires. Not a bad setup, and I haven't had any problems since I put them on. I have no experience towing on them so I can't help you out with that. Here are some pictures:
Hope this helps!
Kenneth
"The ten most horrifying words in the English language are 'I am the Government and I am here to help.'" - Ronald Reagan
2003 F-250-6.0L, SCT W/ Matt's SRL, Edge CTS Insight, MBRP W/ Cat & Muffler Delete + 6" tip, '05 Headlights, Zoodad, High Idle, Marinco Mod, DC-1's
kosk0100 is offline
post #4 of 6 Old 07-01-2010, 10:43 PM Thread Starter
Reg Bichel's Avatar
G'day M8 (Mate),
Well that gives me some confidence to eventually go ahead and give this combo a go. Thanks for the reply.
Here's some pics of my Aussie rig. You blokes warned any of us that the up-spec and mod bug would bite, latch on and not let go. Well I can't shake little bugger...more mods to come...just gotta keep workin
Name:	Aussie 2005 F250 7.3L Powerstroke (1).JPG
ID:	15871   Click image for larger version
Name:	Aussie 2005 F250 7.3L Powerstroke (3).JPG
ID:	15873   Click image for larger version
Name:	Aussie 2005 F250 7.3L Powerstroke Cab.jpg
ID:	15874   Click image for larger version
Name:	Aussie 2005 F250 7.3L Powerstroke Cab (2).jpg
post #5 of 6 Old 07-05-2010, 07:18 PM
Hope this helps!
Your truck would look SO much sexier if the windows were tinted to match the rear.
Overfueld7Three is offline
post #6 of 6 Old 07-05-2010, 07:57 PM
YodersStrokin96's Avatar
agree'd and Reg nice truck and really weird interior ha ha
--->Zach<---
1996 CCLB, XLT PSD, 4x4,
Auto, Autometer Guages, Matts Tunes, Stage 1's, AIS Water/Meth, Intake/Intercooler,
D66, gutted EBPV, Built Tran. dual napa Tran. Cooler and . . . More
1995 Ranger XL 2.3L 2x4
More Photos -->
YodersStrokin96 is offline
