Sponsored by Discount Tire |
Larger Tires
Does anyone know what the largest tire size I can put on a 2010 F-250 crew cabis without a lift. I plan to lift it latter but I will be needing tires soon.
Assuming you have stock 16" rims, I believe you can run 285/75/16 fine without any rubbing. Some people have said 295/75/16 or 305/75/16 will fit with minor rubbing.
EDIT: I read 2001 not 2010. I don't know if this holds true for the new PSDs. |
I don't think they have 16" wheels any more nor will they fit correctly without any issues on newer super duty's.
..I have seen 35's on stock 2010's with no lift.
The truck has 20's on it.
I think that the largest without a lift is 35".
i have a 99 SD with 305 s and its completely stock. No rubbing whatsoever
