03 f250 tires - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
post #1 of 5 Old 06-27-2010, 08:40 AM Thread Starter
03 f250 tires
Hi guys, I just bought a 2003 f250 6.0. The back fender says 4x4 sport. The previous owner put on 16x8 aftermarket wheels with 265 tires. I was wonder if I can bump them up to 305-70r16's with no rubbing. Im looking for a fairly aggressive tire, but nothing too extreme, maybe just an MT. Thanks for any input, the suspension is all stock with rancho shocks.
-Brad
Brad_9876 is offline
post #2 of 5 Old 07-01-2010, 04:37 PM
yes. Thats what I have on my truck. 305 70 16 mud tires. Sucks cause I bought them 8 months ago and they are noisy as hell. Drives me up a wall sometimes. Im not replacing them cause I wanna wear them out before I buy new tires andif I sell them it will be at a loss so i might as well keep them till they are wasted
Unless you dont mind a lot of road noise I would go with a aggressive AT rather than a MT
Rob454 is offline
post #3 of 5 Old 07-01-2010, 06:05 PM Thread Starter
Thanks a lot, I was more curious about the size in general and you answered it for me. Thanks
post #4 of 5 Old 07-02-2010, 12:28 AM
Reg Bichel's Avatar
G'day M8(Mate),
I've got an Aussie 2005 F250 7.3L Powerstroke which is the same as your 2003. Ford Aust kept planting the 7.3 into the 99-03 Style F250s until late 2005 as special RH Drive built trucks.
I've been running Toyo OPAT AT 305 70R 16 tyres and on 10" rims and have no rubbing problems. There is a very slight touch on the inside of the front mud flaps but nowhere else.
--Reg.
Aussie spec Brazilian built 2005 (US 2003) F-250 Superduty 4x4 7.3Ltr Powerstroke: Donaldson (AIS) Intake with Zoodad, AIH deleted, DIY CCV & catch can, 26 x 3 Cummins straight through muffler, MBRP Black Tip, Foil Delete, Old Man Emu (OME) HD rear spring set, Front leveler spring, OME Nitrocharger Dual Tower shocks front, OME Nitrocharger shocks rear, Tough Dog Steering Damper, ARB Air Lockers Front & Rear, V10 Tranny cooler in series with Stock Tranny cooler, Deep Tranny Pan, Extra Cooling rear diff cover, ARB HD Front Diff cover, ARB Bull Bar, Kymar Dual Spare Wheel carrier & Rear bumper, Edge Evo with Dash Pod & EGT pyro, Long Range Fuel Tank, OEM Style paint matched wheel arch flares, VMS in Dash GPS Street & Off Road Navigator, Toyo OPAT AT 305 70R 16 on 10 Rims.
Reg Bichel is offline
post #5 of 5 Old 07-02-2010, 07:42 PM
Firefighter Member
Shockley6.0's Avatar
you should buy mine.....they are 315/75 R16's....they rub at a full turn on the leafs but they are pro comp extreme M/T's.....and not that much...pm me if your interested.
-Scott
Shockley6.0 is offline
