Will these different sized tires fit? - Ford Powerstroke Diesel Forum
Sponsored by Discount Tire
Old 06-22-2010, 12:46 PM
Hello
I have found a good set of tires for a cheap price. But I am ignorant when it comes to tires and I am not familiar with the tire numbers. I am not sure if they will fit or not and what the difference is.
I currently have 295/75 16 tires on my 2001 F350 4x4 with stock rims and no lift.
The tires I have found are 305/70 16.
Will these other tires work???? or will I need spacing and if so I do I go about that.
Remember I am completing ignorant. If you can explain the number system as well that would be great!.
Thanks
Old 06-22-2010, 06:27 PM
Metric To Inches Tire Size Conversion
Go there and plug in the numbers for the tire sizes and rims...make sure you hit reset when you put in a new tire size after you have calculated one already. It will tell you in standard sizing
Old 06-22-2010, 07:35 PM
Firefighter Member
i know i fit my 315/75/r16s on my truck but mine is leveled. Only think is at a full turn it rubs on the leaf springs. I have mine forsale right now just beacuse I want 20's or money. Other than that I like them.
